I’m currently experimenting with the Programmable Source and vtkUnstructuredGrid output, but I’m having trouble getting it to work. I’m simply trying to generate a single polyhedral cell, and I’m fairly certain I have the right source:
import re
cell_str = \
1 :: polyhedra
n: 8
1 :: [0.0 0.0 0.0]
2 :: [1.0 0.0 0.0]
3 :: [1.0 1.0 0.0]
4 :: [0.0 1.0 0.0]
5 :: [0.0 0.0 1.0]
6 :: [1.0 0.0 1.0]
7 :: [1.0 1.0 1.0]
8 :: [0.0 1.0 1.0]
f: 6
10 :: c0: 1 c1: 0 n: 4 (1, 4, 3, 2)
15 :: c0: 1 c1: 0 n: 4 (1, 2, 6, 5)
13 :: c0: 1 c1: 0 n: 4 (1, 5, 8, 4)
12 :: c0: 1 c1: 0 n: 4 (7, 3, 4, 8)
14 :: c0: 1 c1: 0 n: 4 (7, 8, 5, 6)
19 :: c0: 1 c1: 0 n: 4 (7, 6, 2, 3)
coords = []
n_index = 0
n_nodes = 0
n_faces = 0
node_line = 0
face_line = 0
node_map = {}
connectivity = []
lines = cell_str.split('\n')
cell = int(re.match('(\d+) :: (\S+)', lines[1]).group(1))
facet_pattern = " (\d+) :: c0: (\d+) c1: (\d+) n: (\d+)"
float_pattern = "([-+]?[0-9]*\.?[0-9]+([eE][-+]?[0-9]+)?)"
coord_pattern = " (\d+) :: \[{0} {0} {0}\]".format(float_pattern)
for i, line in enumerate(lines):
node_match = re.match('n: (\d+)', line)
face_match = re.match('f: (\d+)', line)
if node_match:
node_line = i + 2
n_nodes = int(node_match.group(1))
if face_match:
face_line = i + 2
n_faces = int(face_match.group(1))
for line in lines[node_line:node_line + n_nodes]:
mat = re.match(coord_pattern, line)
if mat:
coord = (float(mat[2]), float(mat[4]), float(mat[6]))
node_map[int(mat[1])] = n_index
n_index = n_index + 1
coords.append(coord)
connectivity.append(n_faces)
for line in lines[face_line:face_line + n_faces]:
mat = re.match(facet_pattern, line)
if mat:
facet = (int(mat[1]), int(mat[2]), int(mat[3]), int(mat[4]))
nodes = [node_map[int(i)] for i in re.split("[\(\)]", line)[1].split(',')]
if facet[2] == cell:
nodes.reverse()
connectivity.append(len(nodes))
for id in nodes:
connectivity.append(id)
# Output to Paraview
from paraview import vtk
ids = vtk.vtkIdList()
pts = vtk.vtkPoints()
output = self.GetOutput()
output.Allocate(1, 1000)
for coord in coords:
pts.InsertNextPoint(coord[0], coord[1], coord[2])
output.SetPoints(pts)
for index, id in enumerate(connectivity):
ids.InsertId(index, id)
output.InsertNextCell(42, ids)
However, with Paraview-5.8.1, I currently get the following error:
File "<string>", line 20, in <module>
File "<string>", line 38, in RequestData
AttributeError: 'NoneType' object has no attribute 'group'
It’s clearly coming from the line:
but when I type it in interactively via the Python Shell in Paraview, I get the expected result (i.e., 1)
Any ideas on what is going wrong here?
Thanks!
