Progress bar not progressing 5.10.0
Hi all,
I just installed openfoam12 using Ubuntu 22.04 and when I tried to run the example on the openfoam website the “foamRun” command worked perfect and it ran the simulation. However when I tried to open paraview to view the results by using “paraFoam” it showed an error: “QStandardPaths: wrong permissions on runtime directory /run/user/1000/, 0755 instead of 0700
I/O : uncollated”.
Paraview then opened with a progress bar at the bottom right of 7.7GB, however this download doesn’t seem to progress, it is stuck at 1.0/7.7 GB, and I can’t seem to figure out why. Even if I close Ubuntu and paraview and reopen simply as an app it doesn’t work and has the progress bar.
This is ParaView discourse, not paraFOAM or OpenFOAM, you want to reach out to paraFOAM maintainers for help.
If not, please use ParaView, you can download it here: https://www.paraview.org/download/
This is not a progress bar, this is your local memory usage.
You can just use ParaView by clicking on the buttons, eg File → Open
