Projecting CFD results into a FEM mesh
Hi
I have some results from a CFD analysis and I want to project (I’m not sure of the right term map, interpolate?) the pressure values available at nodes to pressure values in each element for the FEM mesh. The meshes came from the same geometry, but are quite different in density, type of elements, etc… Is there any way to perform this kind of operation using paraview?
Thanks for the support
Sounds like Filters -> Resample With Dataset filter.
Thanks! That seems to work fine.
