For a filter, I need the following input properties:
Value1, a value name from a list of strings - “<none>” by default
Min1, Max1 and Steps1, for some loop.
Requirements and dependencies:
a) Min1, Max1 and Steps1 should only be active if Value1 is not “<none>”
b) Steps1 must be positive (minimum 1)
c) Max1 must be larger than Min1 (and also the other way round, of course)
Furthermore:
Value2, a second value name from the same list of strings - “<none>” by default
Min2, Max2 and Steps2, for a second loop.
Requirements and dependencies for this last group are same as above, thus a), b) and c), plus the following:
d) Value2 is only active if Value1 is not “<none>”
On top of that, I want some graphical display in the properties panel that visualizes the current choice of the user. Of course this display would depend on all the above properties.
For me the easiest to implement would be to just write some custom property widget for all the above properties that fulfills all the above requirements and dependencies, plus provides the graphical display.
A more “Paraview like” solution would be to go for a more generic solution, like the following - but there I have some problems to see how to achieve this!
- a) and d) For these I would need some kind of decorator that activates other properties if one does not have a certain value: Maybe I would somehow find a way to achieve this, looking at examples within the Paraview code.
- b) can be achieved with an
IntRangeDomain, if I provide not only the minimum value (1), but also some reasonable maximum - c) is in a way realized for the
Thresholdfilter, but in a way that it looks like I still cannot use it: It assumes that the values are attributes, and a value range is specified by that attribute - which is not my use case! I only need to ensure max>min - The visualization could be realized by some “visualize only” property widget - if only I knew how to attach it to the other properties in such a way that it is triggered if they change, but without a way to change the properties through this property widget. I might have to specify some dummy
information_onlyproperty and attach it to that property widget
What would Paraview experts who know very well the logic of these plugin XML files do for this problem?
For me it would be the fastest if I just write a custom property widget with the means of Qt. On the other hand would I still be keen to better understand the Paraview plugin XML logic and all the nice things that you can do with it!
