Hi there!
I made a filter called MainProxy.cxx with the following xml:
<ProxyProperty name="ProxyExample"
command="SetProxyExample"
label="Proxy Example">
<ProxyListDomain name="proxy_list">
<Proxy group="proxy_examples"
name="ProxyExample1" />
name="ProxyExample2" />
</ProxyListDomain>
</ProxyProperty>
but the client-server wrapper does not generate the associated code in the MainProxyClientServer.cxx. I made sure to follow the logic of the Kernel setup in the PointInterpolator.
If I edit the MainProxyClientServer.cxx and add this piece of code:
if (!strcmp("SetProxyExample", method) && msg.GetNumberOfArguments(0) == 3)
AbstractProxyExample* temp0;
if (vtkClientServerStreamGetArgumentObject(msg, 0, 2, &temp0, "AbstractProxyExample"))
op->SetProxyExample(temp0);
return 1;
if (!strcmp("GetProxyExample", method) && msg.GetNumberOfArguments(0) == 2)
AbstractProxyExample* temp20;
temp20 = (op)->GetProxyExample();
resultStream.Reset();
resultStream << vtkClientServerStream::Reply << (vtkObjectBase*)temp20 << vtkClientServerStream::End;
return 1;
everything works, but it dissapears after compilation. ProxyExample1 and ProxyExample2 are children of AbstractProxyExample.
Any hints on why this could happen? Do I have to include more information?
Thank you,
Patrick Laurin
