I build pv5.9rc2 with vs2017x64 (qt5.12) on windows7 using the default configuration. However, when I run the application, the GUI show below:
How did you configure ParaView before building ?
FYI @cory.quammen
Please click the checkbox “Show full messages” and copy that text (via the “Copy to Clipboard” button) and paste it here.
ERROR: In E:\ParaView-v5.9.0-RC2\VTK\IO\XMLParser\vtkXMLParser.cxx, line 379
vtkPVXMLParser (0000000004752CC0): Error parsing XML in stream at line 273, column 41, byte index 11570: not well-formed (invalid token)
ERROR: In E:\ParaView-v5.9.0-RC2\Remoting\ServerManager\vtkSIProxyDefinitionManager.cxx, line 526
vtkSIProxyDefinitionManager (00000000046B6AB0): No proxy that matches: group=misc and proxy=SaveScreenshot were found.
ERROR: In E:\ParaView-v5.9.0-RC2\Remoting\ServerManager\vtkSMProxy.cxx, line 1699
vtkSMCinemaVolumetricImageExtractWriterProxy (0000000006E62680): Failed to create subproxy: SaveScreenshot
vtkSMImageExtractWriterProxy (0000000004958370): Failed to create subproxy: SaveScreenshot
vtkSMImageExtractWriterProxy (0000000004AC8310): Failed to create subproxy: SaveScreenshot
vtkSMCinemaVolumetricImageExtractWriterProxy (00000000091AB500): Failed to create subproxy: SaveScreenshot
vtkSMImageExtractWriterProxy (00000000091ADFC0): Failed to create subproxy: SaveScreenshot
vtkSMImageExtractWriterProxy (00000000091AF760): Failed to create subproxy: SaveScreenshot
vtkSIProxyDefinitionManager (00000000046B6AB0): No proxy that matches: group=annotations and proxy=GridAxes3DActor were found.
vtkSIProxyDefinitionManager (00000000046B6AB0): No proxy that matches: group=misc and proxy=ViewLayout were found.
I just set the QT directory.
@cory.quammen: Looks like broken svg support.
Indeed. @lyz make sure there is a qsvg.dll file in your Qt installation. In the binaries we provide on paraview.org, this is found under C:\Program Files\ParaView 5.9.0-RC2-Windows-Python3.8-msvc2017-64bit\bin\imageformats
As for the error messages, I think I see the problem in one of the XML files. Proposed fix here: https://gitlab.kitware.com/paraview/paraview/-/merge_requests/4642
