Hi, I’m trying to use the ProcessThreadPool class of python but I get the following error: Some resources might leak . I’m trying to understand if it’s because I run my python script under pvpython or not.
What am I doing?
I have a grid of points from which I want to extract the streamTracer filter. Essentially I give to the python script the list of the points and he moves the filter around the script saving each time a data file. Since I have more that 5.000 points (I could have easily >30k points), it turns that I need to save a lot of files and it keeps >2 minutes. I was thinking on a multi process solution (multi thread doesn’t improve performance), but I cannot get rid of the following error:
pvpython export_streamlines.py receivers.geojson 0.5 3
/Applications/ParaView-5.11.0-RC2.app/Contents/Libraries/lib/python3.9/multiprocessing/resource_tracker.py:96: UserWarning: resource_tracker: process died unexpectedly, relaunching. Some resources might leak.
warnings.warn('resource_tracker: process died unexpectedly, '
Here my code:
from paraview.simple import *
import os
import json
import time
from concurrent.futures import ProcessPoolExecutor as pool
def extract_and_save(feature,streamTracer1):
x = feature['geometry']['coordinates'][0]
y = feature['geometry']['coordinates'][1]
z = feature['geometry']['coordinates'][2]
ID = feature['properties']['PK']
Center = [x,y,z]
streamTracer1.SeedType.Center = Center
SaveData('../streamlines/'+str(ID)+'.txt', proxy=streamTracer1, ChooseArraysToWrite=1,
PointDataArrays=['IntegrationTime', 'U [m/s]'],
CellDataArrays=['ReasonForTermination', 'SeedIds'],
FieldDataArrays=['CasePath'])
start_time = time.time()
if len(sys.argv)<4:
print("Inputs: <geojson path> , <Radius> , <numberOfPoints> ")
sys.exit(1)
with open(sys.argv[1], 'r') as json_file:
data = json.load(json_file)
# get the time-keeper
timeKeeper1 = GetTimeKeeper()
# load state
LoadState('../streamlines.pvsm')
# find source
streamTracer1 = FindSource('StreamTracer1')
# set active source
SetActiveSource(streamTracer1)
#Inputs
streamTracer1.SeedType.Radius = float(sys.argv[2])
streamTracer1.SeedType.NumberOfPoints = int(sys.argv[3])
# save data
if not os.path.exists("../streamlines"):
os.makedirs("../streamlines")
#for feature in data['features']:
#extract_and_save(feature,streamTracer1)
with pool(max_workers=1) as exe:
_ = exe.submit(extract_and_save, data['features'])
print('[Finished in: %s seconds ]' % (time.time() - start_time))
