Dear all,
I am trying to automatise my post-processing of an OpenFOAM case using pvpython.
I obtain the result that I need and I want, however, I want to improve the code. I am really new, and it is my first time with pvpython/python and paraview.
The problem is that when I execute my pvpython code, I have a paraview GUI that opens while the code is running. But I do not want it to appear, I just want to execute the script and obtain the results without any extra window opening.
The code is built using the trace tool of paraview. I tried to suppress the code lines that open the windows but if I do so, the date do not get updated when I change the time (timestep) in which. E.g. I want to make the time average of a slice averaged property, if I do not show the window, the data, even if I do change properly the time step, do not get updated.
The code is the following:
import sys
import numpy as np
import os
import signal
import vtk.util.numpy_support as nps
import matplotlib.pyplot as plt
from numpy import linalg as LA
import mathfrom paraview.simple import *
testingFunctionsfoam = OpenFOAMReader(FileName=’/home/saddik/Desktop/LongerSim/LongerSim.foam’)
testingFunctionsfoam.MeshRegions = [‘internalMesh’]
testingFunctionsfoam.CellArrays = [‘H2’]
testingFunctionsfoam.Decomposepolyhedra = 0animationScene1 = GetAnimationScene()
timeKeeper1 = GetTimeKeeper()
timesteps = timeKeeper1.TimestepValues
numTimesteps = len(timesteps)animationScene1.UpdateAnimationUsingDataTimeSteps()
testingFunctionsfoam.SkipZeroTime = 0
renderView1 = GetActiveViewOrCreate(‘RenderView’)
layout1 = GetLayout()
materialLibrary1 = GetMaterialLibrary()
renderView1.Update()
cellSize1 = CellSize(Input=testingFunctionsfoam)
cellSize1.ComputeVertexCount = 0
cellSize1.ComputeLength = 0
cellSize1.ComputeArea = 0renderView1.Update()
SetActiveSource(cellSize1)
Data = servermanager.Fetch(cellSize1)Data0 = Data.GetBlock(0)
Volume_i = Data0.GetCellData().GetArray(‘Volume’)Volume_i_np = nps.vtk_to_numpy(Volume_i)
Volume_TOT = np.sum(Volume_i_np)delta = []
for i in range(0, numTimesteps):
H2_i = Data0.GetCellData().GetArray(‘H2’)
H2_i_np = nps.vtk_to_numpy(H2_i)
H2_i_Volume_i = np.multiply(H2_i_np, Volume_i_np)
sumH2_i_Volume_i = np.sum(H2_i_Volume_i)
H2_avg = sumH2_i_Volume_i / Volume_TOT
H2_i_H2_avg_Volume_i = np.multiply(np.absolute(H2_i_np - H2_avg), Volume_i_np)
sum_H2_i_H2_avg_Volume_i = np.sum(H2_i_H2_avg_Volume_i)
if sumH2_i_Volume_i < 1e-16:
sumH2_i_Volume_i = 1
sum_H2_i_H2_avg_Volume_i = 0
delta_i = 1 - 0.5*(sum_H2_i_H2_avg_Volume_i/sumH2_i_Volume_i)delta.append(delta_i)
cellSize1Display = Show(cellSize1, renderView1, ‘GeometryRepresentation’)
animationScene1.GoToNext()
print(i)
print(delta[i])
Basically, If I suppress the line
The timestep do change but the information do not get updated.
I want to execute the code without any window opening.
Do you have any advice?
Thank you.
