When I run pvpython, it does not initialize with the famous "from paraview.simple import * ".
Is there a way to execute a series of commands when we start up pvpython? Examples are above, or setting a “Reverse Connection” in order to connect to a back end server.
pvpython is simply a standard Python interpreter. I don’t think we should do much more than that standard Python interpreter does. It’s best for users to realize that it is a standard Python interpreter and treat it as such.
The reason for the question is I am trying to create scripts that automate pvpython connecting to a backend server. I would prefer not having the user be forced to type the Reverse Connection command. This is a request from Greg W.
Seb,
This is for other users. Thus, if I hard code pvpython with a script (of mine), users won’t then be able to run their own script. What I’m trying to do is create a client, and server pair of scripts that allow a user to run pvpython2cluster (with all of the magic hidden). If I am then passing in a script under the covers, users then won’t be able to do pvpython2cluster usersScript. Or, am I missing something?
Seb, that doesn’t work. Correct, wait-cluster executes, then user-script executes, works. However, if we run wait-cluster.py, Python ends and we get a command prompt back. This is correct behavior normally, but not in this case.
