Hello, my goal is to save time by running paraview through pvpython rather than the gui. What I’m doing is loading a folder of data files and then using them to create an animation. (running linux mint)
The initial steps aside from the source of the datafiles is always the same so I want to automate the initial steps through pvpython command line as much as possible
Here is the initial script I’m using
I have two main problems and a question.
- pvpython from command line simply won’t work. When I try
pvpython WB.py
I get
File "WB.py", line 11, in <module>
animationScene1.UpdateAnimationUsingDataTimeSteps()
File "/usr/lib/python2.7/dist-packages/paraview/servermanager.py", line 414, in __getattr__
return getattr(self.SMProxy, name)
AttributeError: UpdateAnimationUsingDataTimeSteps
Is there an easier way to load the data files other than as shown in the script, this?
- create a new ‘CSV Reader’
pararesults0 = CSVReader(FileName=[’/home/ace/wtresults112518/pararesults001.csv’, etc
I need to load a different folder of files each time. Ordinarily I’d load this into paraview by clicking on a single series of files but in the command line the loading is 99 names long.
- After I create the visualization through pvpython. would it be possible to manipulate it via the gui Ie turn it around, look at different variables?
