Hi, I use pvpython scripting to convert a bunch of vtk files to png images in paraview.
The logic is to:
(i) define main function vtkToImg(), which reads one vtk file and save it as one screenshot (.png);
(ii) use for-loop to iteratively run the main function for all vtk files.
The script runs well for single core, but processing vtk file one by one is very time-cosuming. So I try to use multi-processing module to run the script in parallel, and the code looks like:
import multiprocessing as mp
from paraview.simple import *
def getvtkFile(path_vtk) # get vtk files in path_vtk
def vtkToImg(vtkFile, path_img) # main function with 2 inputs
if __name__ == "__main__": # parallel
path_vtk = './sequencedVTK/'
path_img = './sequencedIMG/'
# get vtk files
vtkFiles = getvtkFile(path_vtk)
# build pool including 8 processors
pool = mp.Pool(8)
pool.starmap(vtkToImage, [(vtkFiles[i], path_img) for i in range(len(vtkFiles))])
pool.close()
But when running this s in the terminal, I received the error AttributeError: ‘Pool’ object has no attribute 'starmap’ I find this error appears due to I apply python2 instead of python3.
So my question is:
(1) how to apply python3 with pvpython?
(2) is it reasonable to use multi-processing module for pvpython parallel? Or pvpython has other better methods to run in parallel?
I would be very appreciated if anyone can give me some help!
