I am working with OpenFOAM for CFD simulations and using Paraview for post-processing and saving data from the simulation.
This time I am running a bunch of simulations and using pvpython to save data. I have already done this before successfully, but this time the script is not working. I found the error when calling functions that render views, like Show() or CreateOrRenderView() it show me on the prompt:
Stack dump:
Segmentation Fault (core dumped)
When I try to run CreateView(‘Camera’) it throws:
ERROR: In /home/ubuntu/OpenFOAM/ThirdParty-dev/ParaView-5.6.0/ParaViewCore/ServerImplementation/Core/vtkSIProxyDefinitionManager.cxx, line 522
vtkSIProxyDefinitionManager (0x55bfefe0e720): No proxy that matches: group=views and proxy=Camera were found.
I’m relatively new to Paraview, just need to save the data of the last time step programmatically, and to ensure this before I have used the GetActiveView() associated with DATA_SOURCE.TimeStepValues[-1], and for the fields I’ve used PROXY.PointDataArrays = [‘field1’, …].
I am using Paraview5.6 in Linux Mint, A log of the pvpython --cslog is attached.
Any help is welcome.
