I am using pverser on a HPC environment. when I connect to the server from a ui client I get the error.
display not accessible on the server side.
As far as I’ve read, it is because the x server is not running on the server nodes. However, I checked the nodes configuration and the xservers are runnig.
This is the error log in case it help.
Loguru caught a signal: SIGSEGV
Stack trace:
21 0x403ca9 /gpfs/runtime/opt/paraview/5.9.0/bin/pvserver() [0x403ca9]
20 0x7fe6e49d0545 __libc_start_main + 245
19 0x403f9a /gpfs/runtime/opt/paraview/5.9.0/bin/pvserver() [0x403f9a]
18 0x7fe6e914ae90 vtkTCPNetworkAccessManager::ProcessEventsInternal(unsigned long, bool) + 544
17 0x7fe6e7fd7b69 vtkMultiProcessController::ProcessRMIs(int, int) + 329
16 0x7fe6e7fd8272 vtkMultiProcessController::ProcessRMI(int, void*, int, int) + 866
15 0x7fe6e9a6356b vtkPVSessionServer::OnClientServerMessageRMI(void*, int) + 523
14 0x7fe6e9a63fd7 vtkPVSessionServer::GatherInformationInternal(unsigned int, char const*, unsigned int, vtkMultiProcessStream&) + 167
13 0x7fe6e9a5a992 vtkPVSessionCore::GatherInformation(unsigned int, vtkPVInformation*, unsigned int) + 34
12 0x7fe6e9a5ac29 vtkPVSessionCore::GatherInformationInternal(vtkPVInformation*, unsigned int) + 377
11 0x7fe6e0dd508a vtkPVRenderingCapabilitiesInformation::CopyFromObject(vtkObject*) + 10
10 0x7fe6e0dd5152 vtkPVRenderingCapabilitiesInformation::GetLocalCapabilities() + 178
9 0x7fe6d34c350b vtkOpenGLRenderWindow::SupportsOpenGL() + 187
8 0x7fe6d3579af2 vtkXOpenGLRenderWindow::WindowInitialize() + 18
7 0x7fe6d35790ba vtkXOpenGLRenderWindow::CreateAWindow() + 1146
6 0x7fe6d290bc64 /lib64/libGLX.so.0(+0x4c64) [0x7fe6d290bc64]
5 0x7fe6746b89d7 glXCreateContextAttribsARB + 87
4 0x7fe6746c2881 /lib64/libGLX_nvidia.so.0(+0x76881) [0x7fe6746c2881]
3 0x7fe67469ab88 /lib64/libGLX_nvidia.so.0(+0x4eb88) [0x7fe67469ab88]
2 0x7fe67469ab1c /lib64/libGLX_nvidia.so.0(+0x4eb1c) [0x7fe67469ab1c]
1 0x7fe6453a6188 /lib64/libnvidia-glcore.so.460.27.04(+0xd5c188) [0x7fe6453a6188]
0 0x7fe6453a967c /lib64/libnvidia-glcore.so.460.27.04(+0xd5f67c) [0x7fe6453a967c]
( 23.359s) [pvserver ] :0 FATL| Signal: SIGSEGV
/var/spool/slurmd/job290508/slurm_script: line 61: 32644 Segmentation fault /gpfs/runtime/opt/paraview/5.9.0/bin/pvserver -display :0.0 --force-offscreen-rendering
PServer Initialization completed
Job completed
Any thoughts?
Thanks.
