I am getting the following dump when trying to run pvserver 5.9.1 in reverse-connection mode.
On the client side it appears to read the file (openfoam reader) and then if fails to render on screen getting the following.
I am total lost as to where/how to debug this problem.
Any help is appreciated.
Thanks
Process id 887493 Caught SIGSEGV at 0x68 address not mapped to object
Program Stack:
WARNING: The stack trace will not use advanced capabilities because this is a release build.
0x147f13092410 : ??? [(???) ???:-1]
0x147efbde0c23 : ??? [(???) ???:-1]
0x147efbdd6aea : OSMesaCreateContextAttribs [(libOSMesa.so.8) ???:-1]
0x147efd302623 : vtkOSOpenGLRenderWindow::CreateOffScreenWindow(int, int) [(libvtkRenderingOpenGL2-pv5.9.so.1) ???:-1]
0x147efd28f0ca : vtkOpenGLRenderWindow::Start() [(libvtkRenderingOpenGL2-pv5.9.so.1) ???:-1]
0x147ef8dba275 : vtkRenderWindow::Render() [(libvtkRenderingCore-pv5.9.so.1) ???:-1]
0x147efd291172 : vtkOpenGLRenderWindow::Render() [(libvtkRenderingOpenGL2-pv5.9.so.1) ???:-1]
0x147f0c9c7d32 : vtkPVProcessWindow::PrepareForRendering() [(libvtkRemotingViews-pv5.9.so.1) ???:-1]
0x147f0c9efa25 : ??? [(???) ???:-1]
0x147f0c9daefe : vtkPVRenderView::Render(bool, bool) [(libvtkRemotingViews-pv5.9.so.1) ???:-1]
0x147f0c9d0cd1 : vtkPVRenderView::StillRender() [(libvtkRemotingViews-pv5.9.so.1) ???:-1]
0x147f11dd0138 : vtkPVRenderViewCommand(vtkClientServerInterpreter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&, voi$
0x147f1082d8c2 : vtkClientServerInterpreter::CallCommandFunction(char const*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStr$
0x147f1082de25 : vtkClientServerInterpreter::ProcessCommandInvoke(vtkClientServerStream const&, int) [(libvtkRemotingClientServerStream-pv5.9.so.1) ???:-1]
0x147f1082e2ce : vtkClientServerInterpreter::ProcessOneMessage(vtkClientServerStream const&, int) [(libvtkRemotingClientServerStream-pv5.9.so.1) ???:-1]
0x147f1082e38d : vtkClientServerInterpreter::ProcessStream(vtkClientServerStream const&) [(libvtkRemotingClientServerStream-pv5.9.so.1) ???:-1]
0x147f114eb892 : vtkPVSessionCore::ExecuteStreamInternal(vtkClientServerStream const&, bool) [(libvtkRemotingServerManager-pv5.9.so.1) ???:-1]
0x147f114ebac2 : vtkPVSessionCore::ExecuteStreamSatelliteCallback() [(libvtkRemotingServerManager-pv5.9.so.1) ???:-1]
0x147f0fc64c50 : vtkMultiProcessController::ProcessRMI(int, void*, int, int) [(libvtkParallelCore-pv5.9.so.1) ???:-1]
0x147f0fc64e7f : vtkMultiProcessController::BroadcastProcessRMIs(int, int) [(libvtkParallelCore-pv5.9.so.1) ???:-1]
0x147f0fc65195 : vtkMultiProcessController::ProcessRMIs(int, int) [(libvtkParallelCore-pv5.9.so.1) ???:-1]
0x4016ee : ??? [(???) ???:-1]
0x147f1307e4a3 : __libc_start_main [(libc.so.6) ???:-1]
0x40175e : ??? [(???) ???:-1]
