I’m trying to create a proxy for a python filter. On the client side, I would like the proxy to be able to provide an id. I tried 2 different property mechanisms for that purpose, but I am facing 2 issues:
- The proxy property is not updated after the pipeline has been updated: see GetID2 below.
- I did not find a proper way to implement a property getter that fits the data type: below GetID never returns an id, always None.
I work with paraview 5.6 and python 3.6 (all from anaconda).
The simplified proxy code, the file is named proxies.py, I used a source filter just for the demonstration :
from vtkmodules.util.vtkAlgorithm import VTKPythonAlgorithmBase
from paraview.util.vtkAlgorithm import smproxy, smproperty, smdomain
from vtkmodules.vtkCommonDataModel import vtkMultiBlockDataSet
@smproxy.source()
class IDProxy(VTKPythonAlgorithmBase):
def __init__(self, *args, **kwargs):
super().__init__(nInputPorts=0,
nOutputPorts=1,
outputType='vtkMultiBlockDataSet')
self.id = 0
self.id += 1
print('RequestData: id=', self.id)
return 1
@smproperty.xml(xmlstr='''
<IdTypeVectorProperty
command="GetID"
information_only="1"
name="IDInfo"
si_class="vtkSIDataArrayProperty"/>
command="GetID"
information_property="IDInfo"
name="ID"
si_class="vtkSIDataArrayProperty">
<ArraySelectionDomain name="array_list">
<RequiredProperties>
<Property function="ArrayList" name="IDInfo"/>
</RequiredProperties>
</ArraySelectionDomain>
</IdTypeVectorProperty>
def GetID(self):
print('GetID: id=', self.id)
return self.id
@smproperty.dataarrayselection(name="ID2")
def GetID2(self):
from vtkmodules.vtkCommonCore import vtkDataArraySelection
x = vtkDataArraySelection()
print('GetID2: id=', self.id)
x.AddArray('%d' % self.id)
return x
The test script:
from pathlib import Path
from paraview import simple
simple.LoadPlugin(str(Path(__file__).parent / 'proxies.py'))
from paraview.simple import IDProxy
proxy = IDProxy()
print('ID id=', proxy.ID)
print('ID2 id=', proxy.ID2)
proxy.UpdatePipeline()
print('ID' id=, proxy.ID)
The output I get:
GetID2: id= 0
GetID: id= 0
GetID: id= 0
GetID2: id= 0
ID id= None
ID2 id= ['0']
RequestData: id= 1
ID id= None
ID2 id= ['0']
Thanks for any help.
