Hello all.
I am attempting to create a script to automate placing numerous cones into a paraview scene for me. I have run into issues with the following code block:
tree = Cone()
tree.Center = treeCenter.split(',')
tree.Radius = treeRadius
tree.Height = treeHeight
tree.Direction = 0,0,1
I get type errors from this code, which do not still occur if I instead manually type the data into the paraview GUI python shell.
Do you have an example of the error that occurs?
Cc: @mwestphal
Yes. The whole error reads like this:
File "<string>", line 37, in <module>
File "/home/brad/ParaView/lib/python3.7/site-packages/paraview/servermanager.py", line 489, in __setattr__
setter(self, value)
File "/home/brad/ParaView/lib/python3.7/site-packages/paraview/servermanager.py", line 2626, in setProperty
return self.SetPropertyWithName(propName, value)
File "/home/brad/ParaView/lib/python3.7/site-packages/paraview/servermanager.py", line 357, in SetPropertyWithName
prop.SetData(arg)
File "/home/brad/ParaView/lib/python3.7/site-packages/paraview/servermanager.py", line 863, in SetData
self.SMProperty.SetElement(idx, val)
TypeError: SetElement argument 2:
I think there’s just one line missing yet
. What’s the full TypeError
block?
Oh, I suspect it is your treeCenter.split(',')
line. That is a list of strings rather than a list/tuple of integers as I expect Center
probably wants. Does map(int, treeCenter.split(','))
work?
Tested that out, got a different error, but on the line prior. I should’ve mentioned that line 36 is the treeCenter.split(',')
line.
File "<string>", line 36, in <module>
setter(self, value)
prop.SetData(arg)
File "/home/brad/ParaView/lib/python3.7/site-packages/paraview/servermanager.py", line 846, in SetData
if not self.GetRepeatable() and len(values) != self.GetNumberOfElements():
TypeError: object of type 'map' has no len()
Right, Python3 made those iterables. Wrap the map()
call with tuple()
Oh I see! Forgive me, I’m not the most familiar with python.
That appears to have worked! Cheers, Ben!!!
