I am trying to create a script to automate some simulation calculations which would then be applied using the Calculator() filter in Paraview on my objects. The issue I’m having is that for some reason those codes, when run in the python shell causes paraview to freeze (Paraview isn’t responding). However when I run those same codes on pvpython they run without a hitch. How can I solve this issue? Other simpler scripts like making cubes or print a string don’t cause any issue.
I’m using Windows 10, Paraview 5.7.0. The simulation calculations are done with Cantera framework.
Thanks
Update, got this error message:
File "<console>", line 1, in <module>
File "C:\Users\z004453p\AppData\Roaming\Python\Python37\site-packages\CRN_test.py", line 15, in <module>
class CRN:
File "C:\Users\z004453p\AppData\Roaming\Python\Python37\site-packages\CRN_test.py", line 47, in CRN
fuel = ct.Solution('ar31.mod.cti')
File "interfaces\cython\cantera\base.pyx", line 29, in cantera._cantera._SolutionBase.__cinit__
File "interfaces\cython\cantera\base.pyx", line 50, in cantera._cantera._SolutionBase._init_cti_xml
cantera._cantera.CanteraError:
CanteraError thrown by ct2ctml_string:
Error executing python while converting input file:
Python command was: 'C:\UserData\z004453p\Documents\ParaView-5.7.0-Windows-Python3.7-msvc2015-64bit\bin\paraview.exe'
thread_buffer_t::get: wait for got_data failed
wait_result_t: timeout elapsed
[code 0x0000 ()]
