Qt 5 support to end starting in ParaView 6.2
To finalize ParaView’s transition to Qt 6, the ParaView team is planning to stop supporting Qt 5 in ParaView starting with ParaView 6.2. Qt 6 will be the only major version of Qt supported by ParaView going forward. ParaView 6.2 is scheduled for release mid-2026.
Qt 5.15 was end-of-lifed earlier this year. Supporting only Qt 6 will reduce ParaView source code maintenance involved in supporting two Qt major versions.
Please let us know if this end of support for Qt 6 will cause problems for your use of ParaView.
In terms of licensing, how does the existing and the potential future license changes in Qt 6 affect the use of ParaView in commercial applications (I mean a ParaView branded application)?
In terms of toolchain, did you face any issues compiling the Qt 6 based ParaView on older machines? We plan to target HPC clusters.
Which license change are you refering to ? I dont see anything.
We usually do not compile Qt6 ourselves and rely on binaries provided by the Qt company
I would not expect Qt to be enabled in a ParaView deplayed on an HPC cluster.
You are right, I mixed it up.
I had in mind the case when you let the ParaView superbuild build Qt from sources.
With Qt6, we do not support building Qt from sources in the paraview superbuild, instead the system Qt is being packaged.
Having heard no objections, we will proceed with removing Qt 5 support in ParaView 6.2.
ParaView 6.2 still supports Qt5. ParaView 6.3 will remove support for it.
