Quaternion mode for glyph orientation
I am using Paraview 5.12.0 (I also tried 5.11.0) on Ubuntu 23.10 (mantic). I want to orient 3D Glyphs directly by using quaternions. I have found in the release notes that it should be possible:
https://www.paraview.org/Wiki/ParaView_Release_Notes#Orienting_by_quaternion_in_3D_Glyph_representation
I have created an array of 4D vectors based on information provided in this discussion: Help with exporting quaternion data in vtu file
However, I cannot use it as an orientation array (only 3D arrays are detected). I cannot find any option to use the ‘Quaternion mode’.
The release notes mentioned above state that there was ’ a choice between direction vector or angles around three axes’. I think that I could also use angles, but how can I ‘tell’ Paraview which option I want to use?
Cheers,
Karol
HI @brzezink
This is working fine here with a 4 components array:
Data:
a.vtp (18.2 KB)
Hello @mwestphal,
Thank you for your answer. Could you please share how you set up this visualisation? Maybe I am missing something straightforward, but I have not been able to find a solution for a while.
Here is how it looks when I try to use Quaternion for orientation:
Only “normals” can be accepted as orientation arrays from your dataset.
Cheers,
Karol
You are using the Glyph filter instead of using the 3DGlyphs representation.
Sorry for posting such a basic problem and thank you for help in solving it!
