I first use ParaView to open a bunch of layouts to plot some data. Those data will be changed if I run some other scripts in the background, when the ParaView GUI is still open.
Is there a way to automatically update the plots in Paraview when it detects changes in the file that generates the plots? I know how to do this by recording a Macro in ParaView using “ReloadFiles”, but I don’t want to click the Macro every time I make a change, as it can happen very frequently.
Or is there another way around this, that I can use a system call to update the plots in the open ParaView GUI via the command line? Then I will be able to write this system call into the scripts that updating the data. I don’t want to close ParaView and re-open it, as it will take some time.
No, you need to manually use the “ReloadFiles” features by right clicking on the source.
Using a live programable source seems to be what you are looking for
Thank you for the reply. Before I try to figure out the live programable source solution, I tried another way. Attached is a simple csv file to be plotted. I recorded a macro called init.py to do the plotting. “auto_run.py” is a script that will update the plot every 1 second. However, when I run auto_run.py, why the plot is not updated in each for loop as I intended, but wait until the whole script finishes running?
