Hello, I am using ParaView as the server and ParaViewWeb as the client visual service. When I increase the model size, the network latency increases and the frame rate on the server side doesn’t seem to change much. Why?
Can you describe better what you mean by latency? Is it that when you drag to rotate the scene, the scene start to rotate later than usually? Or something else?
What setting do you use for interactive quality? When you lower it to 60 do you see similar behavior?
