Why do some particles disappear (apparently when they touch a surface?)
Some particles stick to the walls and get stuck. Is it possible to prevent this?
==> Is it possible to make sure that all the particles that are simulated to enter eventually come out?
After some iterations, when some particles go out of the calculation domain, Paraview crashes. I have done several experiments and I don’t really understand why.
*The parameters I use are the following: *
*Source point : * Number of points: 100 Radius = 1
*ParticleTracer : *
*Force reinjection every Nsteps: 0 (only one particle pool is simulated) * Select Input Vector: velocity
I was not able to produce any particle tracing with your dataset, so something is off, however more investigation is needed to understand what is going on I’m afraid.
Ok I looked, the problem comes indeed from my data : the first timstep (Time = 0) is different from the others and makes the ParticleTracking crash. So I deleted it from the folder.
Sorry, I didn’t understand that the problem came from my data because I was using the temporal interpolator (resample factor = 10) and the simulation crashed only at Time = 11.
Now I have the attached error, and still the 2 following problems:
Yes, you are right.
Apparently neither the LagrangianParticleTracker nor the ParticleTracer is suitable for my case. I will look for a new solution!
Thank you very much for your help!
