Hi there,
I have some 3d point cloud time series data that I’m visualizing for a researcher. I previously wrote a programmable source to enable loading their data and assigning each file to a time step. This has worked well for me, but when it was time for them to switch to a file located in a new place they ended up leaving syntax errors in the script as a result of changing the data’s path.
To help paint the picture of what’s been done so far I’ll include a short screen cast, and these 2 scripts use for the programmable source’s RequestData script
def GetUpdateTimestep(algorithm):
"""Returns the requested time value, or None if not present"""
executive = algorithm.GetExecutive()
return outInfo.Get(executive.UPDATE_TIME_STEP()) \
if outInfo.Has(executive.UPDATE_TIME_STEP()) else None
# This is the requested time-step. This may not be exactly equal to the
# timesteps published in RequestInformation(). Your code must handle that
# correctly.
req_time = int(GetUpdateTimestep(self))
#print(req_time)
from pathlib import Path
import numpy as np
from vtk.numpy_interface import algorithms as algs
from vtk.numpy_interface import dataset_adapter as dsa
def srtkey(a):
return str(a)
pth = Path("/xdisk/chrisreidy/baylyd/Sama_lidar/temp/babel_pcl")
npy_pcls = sorted(list(Path(pth).rglob("*.npy")),key=srtkey)
npy_pcl = npy_pcls[req_time]
all_data = np.load(npy_pcl)
data = all_data[:,:3]
intensity = all_data[:,3]
#print(data)
# make vtk points
pts = vtk.vtkPoints()
pts.SetData(dsa.numpyTovtkDataArray(data,"Points"))
output.SetPoints(pts)
#make single cell
numpts = pts.GetNumberOfPoints()
ids = vtk.vtkIdList()
ids.SetNumberOfIds(numpts)
for a in range(numpts):
ids.SetId(a,a)
output.Allocate(1)
output.InsertNextCell(vtk.VTK_POLY_VERTEX,ids)
#add scalar data to output
output.PointData.append(intensity,"intensity")
and the RequestInformation script
# Code for 'RequestInformation Script'.
def setOutputTimesteps(algorithm, timesteps):
"helper routine to set timestep information"
outInfo.Remove(executive.TIME_STEPS())
for timestep in timesteps:
outInfo.Append(executive.TIME_STEPS(), timestep)
outInfo.Remove(executive.TIME_RANGE())
outInfo.Append(executive.TIME_RANGE(), timesteps[0])
outInfo.Append(executive.TIME_RANGE(), timesteps[-1])
# As an example, let's say we have 4 files in the file series that we
# want to say are producing time 0, 10, 20, and 30.
npy_pcls = list(Path(pth).rglob("*.npy"))
times = [i for i,f in enumerate(npy_pcls)]
print("times are",times)
setOutputTimesteps(self, times)
I want to help prevent this from happening by writing a reader plugin that will just allow them to use the file browser to locate their data instead of using the programmable source script. My plugin seems to have 3 issues I’m struggling to find documented for python plugins
- how to make a python plugin reader read a folder’s contents
- how to use each file in the folder as a time step
- my
vtkPolyDataoutput’sPointDataattribute appears to not work the same way as in the programmable source code evidenced by this errorFile "C:\Users\ohmeg\Documents\paraview_learning\my_test.py", line 80, in RequestData output.PointData.append(intensity,"intensity") AttributeError: 'vtkmodules.vtkCommonDataModel.vtkPolyData' object has no attribute 'PointData'
Here’s the python plugin as I have it written so far.
# same imports as earlier.
from vtkmodules.vtkCommonDataModel import vtkDataSet
from vtkmodules.util.vtkAlgorithm import VTKPythonAlgorithmBase
from vtkmodules.numpy_interface import dataset_adapter as dsa
from paraview.util.vtkAlgorithm import *
from paraview.simple import *
# new module for ParaView-specific decorators.
# to add a source, instead of a filter, use the `smproxy.source` decorator.
@smproxy.source(label="Sama Lidar Source")
class SamaLidarSource(VTKPythonAlgorithmBase):
"""this makes it easier to load a bunch of files from the system"""
def __init__(self):
VTKPythonAlgorithmBase.__init__(self,
nInputPorts=0,
nOutputPorts=1,
outputType='vtkPolyData')
self._filename = None
def _GetUpdateTimestep(self):
def setOutputTimesteps(self):
for timestep in self.timesteps:
outInfo.Append(executive.TIME_RANGE(), self.timesteps[0])
outInfo.Append(executive.TIME_RANGE(), self.timesteps[-1])
print(outInfo)
@smproperty.doublevector(name="TimestepValues", information_only="1", si_class="vtkSITimeStepsProperty")
def GetTimestepValues(self):
return self.timesteps()
def RequestInformation(self, request, inInfoVec, outInfoVec):
self.setOutputTimesteps()
return 1
from vtkmodules.vtkCommonDataModel import vtkPolyData
import vtk
import numpy as np
print("got data request")
req_time = int(self._GetUpdateTimestep())
print(req_time)
output = vtkPolyData.GetData(outInfo, 0)
npy_pcl = self.npy_pcls[req_time]
# make vtk points
#make single cell
ids.SetId(a,a)
output.Allocate(1)
return 1
def do_step(self):
print("got called to change for some reason")
@smproperty.stringvector(name="FileName")
@smdomain.filelist()
@smhint.filechooser(extensions="npy", file_description="Numpy pcd")
def SetFileName(self, name):
"""Specify filename for the file to read."""
print(name)
if self._filename != name and not name is None:
self._filename = name
print("cool just set a file name",name,name is None)
## idea is that we should now create a path from the name,
## get the parent
## rglob it for the other npys
## use them to establish the increments
pth = Path(name)
self.npy_pcls = list(pth.parent.rglob("*.npy"))
self.npy_pcls.sort()
self.timesteps = [i for i,f in enumerate(self.npy_pcls)]
# print("times are",times)
# self.Modified()
Using information from standard examples I’ve been reading 1,2 I came up with a work around where I select a single file from the series and then use that file’s path to determine the parent which I can then query for the paths of all the individual files. This is a pretty unfortunate hack, and I was excited when on this forum I found a useful similar question which seems related to Issue 1. Unfortunately I’m not sure how to decipher the relevant parts of the AMReX reader XML
I’m pretty much lost with regards to how I need to tackle issues 2 & 3 though. Any help is greatly appreciated!
