Reading Multiblock VTK file which inclueds named blocks, gets broken dataset.
Hello.
I have lots multiblock dataset files and tried visualize those dataset with ParaView 5.10.1.
And I’ve met a problem.
Dataset readed from Multiblock VTK file which includes named blocks, will be broken on parallel pvserver of ParaView 5.10.x .
  1. Run pvserver in parallel.
    $ mpirun -n 2 pvserver
  2. Connect paraview to pvserver.
  3. Read test.vtm. (unzip attached testing file test.zip (17.2 KB))
test.vtm has 5 blocks.
In 2 pvserver processes case, first 3 blocks was succeeded to read and last 2 blocks was failed.
It seems reading is succeeded only blocks mapped on head process (rank 0).
Have I mistake to build paraview?
However, prebuilded binary distributed from paraview.org has this problem, too.
And ParaView 5.9.1 or older can read normally.
regards,
Hi @earth2001y,
This was a known issue https://gitlab.kitware.com/paraview/paraview/-/issues/21419 which is currently being fixed in VTK/ParaView.
Best regards,
Julien
Hi @jfausty ,
Thank you for your information about issue.
I expect to the issue will be fixed early.
thanks,
Hi @earth2001y,
The issue should now be fixed in the ParaView master branch.
Kind regards,
Julien
