I am writing a ParaView plugin where I encounter the following 2 cases:
1- for the 1rst I need to iterate over the surrounding adjacents points of a vtkImageData;
2- for the other one, I have to do a whole sweep merging 2 Images + and 2 optionals mask (1 as a 2D image, the second a regular 3D one).
As the 3D image may be large (~300MB for the smallest representative unit test, in float), I was wondering which API is now recommended.
I saw on the not up-to-date VTK reference book at p. 404 that you may use vtkImageIterator and I am wondering if this is still the recommended practice before diving into learning them.
With it I can go into multithreading, but may encounter some issue like this one (https://gitlab.kitware.com/paraview/paraview/issues/14236) under the road.
I also saw this tutorial about DataArray (https://vtk.org/Wiki/VTK/Tutorials/DataArrays), and it seemed to me that the dispatcher is the new way to go.
Which one should I be learning and using for each case ?
If it is the dispatcher do you have a link explaining it ?
Best regards,
PS: The data would always be «float» with only 1 component.
