Hi:
I have a CONVERGECFD data set, I am loading it in ParaView Version 5.8.1 mpi version. When I am using RedistributeDataSet filter, it froze after progressing to 25%.
In the attachment, you will find the data.
Any suggestions?
attachment update: I am not able to upload the data file. its size is 267 MB. Is there any way I can upload that kind of big file?
From what I can tell, it’s the vtkCellCenters filter that’s used internally that’s taking an inordinate amount of time when computing cell-centers for polyhedral cells.
It’s a little hard to tell from the image, but my guess is that the surface is not smooth because no surface normals are available. You can try to use the Generate Surface Normals filter to make the surface appear smoother.
I have tried using Generate Surface Normal, doesn’t improve. As you can see from the attached image below. I agree it’s hard to tell from the image. I was comparing Extract Surface image with Extract Block image. You can see extract block is much smoother. Version 5.8.1 Extract block has some issues when used a python script.
