I have access to a headless box with the following GPU
# nvidia-smi
Sun Sep 11 23:36:32 2022
| NVIDIA-SMI 510.73.05 Driver Version: 510.73.05 CUDA Version: 11.6 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA A100-PCI... Off | 00000000:04:00.0 Off | 0 |
| N/A 31C P0 35W / 250W | 0MiB / 40960MiB | 0% Default |
| | | Disabled |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
I read from this thread that the minimum requirements are CUDA 10.2+ and nvidia-driver 440.33+
Hence I believe the hardware meets the requirements
I am running Paraview 5.10.1 EGL on the headless box
I am connecting to the remote headless box using Paraview 5.10.1 MPI on a Ubuntu 18.04 box
When I try to load the IndeX plugin on the remote headless box, I get the following errors
I am able to perform remote rendering successfully with this setup, I only started looking into Nvidia IndeX today.
By loading the 'pvNVIDIAIndeX' plugin you have accepted the EULA shipped with it.
If that is not acceptable, please restart the application without loading
the 'pvNVIDIAIndeX' plugin.
( 654.606s) [paraview ] vtkSIProxy.cxx:422 ERR| vtkSIProxy (0x24041e0): Failed to create 'vtknvindex_global_settings'. This typically means that ParaView does not know about the request class to create an instance of if. Ensure that it has been correctly wrapped using the client-server wrappers and the wrapping has been initialized. Note class names are case-sensitive. Check for typos. Aborting for debugging purposes.
Loguru caught a signal: SIGABRT
Stack trace:
72 0x40802a /data2/nyue/systems/ParaView/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/paraview-real() [0x40802a]
71 0x7f537a93cc87 __libc_start_main + 231
70 0x407c8a /data2/nyue/systems/ParaView/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/paraview-real() [0x407c8a]
69 0x7f5377d5f120 QCoreApplication::exec() + 128
68 0x7f5377d5662a QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 298
67 0x7f53394dfe13 /data2/nyue/systems/ParaView/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x5ee13) [0x7f53394dfe13]
66 0x7f53783e90db QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 187
65 0x7f537840db35 QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) + 261
64 0x7f537840c8ad QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 1837
63 0x7f5377d57dd8 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 280
62 0x7f5379d3d260 QApplication::notify(QObject*, QEvent*) + 704
61 0x7f5379d3618c QApplicationPrivate::notify_helper(QObject*, QEvent*) + 156
60 0x7f5379d908fb /data2/nyue/systems/ParaView/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libQt5Widgets.so.5(+0x1b68fb) [0x7f5379d908fb]
59 0x7f5379d8e467 /data2/nyue/systems/ParaView/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libQt5Widgets.so.5(+0x1b4467) [0x7f5379d8e467]
58 0x7f5379d3c7cc QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) + 460
57 0x7f5377d57dd8 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 280
56 0x7f5379d3ddc8 QApplication::notify(QObject*, QEvent*) + 3624
55 0x7f5379d3618c QApplicationPrivate::notify_helper(QObject*, QEvent*) + 156
54 0x7f5379ea569b QMenu::event(QEvent*) + 171
53 0x7f5379d73c28 QWidget::event(QEvent*) + 424
52 0x7f5379ea3413 QMenu::mouseReleaseEvent(QMouseEvent*) + 403
51 0x7f5379ea257f /data2/nyue/systems/ParaView/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libQt5Widgets.so.5(+0x2c857f) [0x7f5379ea257f]
50 0x7f5379e9b3fc /data2/nyue/systems/ParaView/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libQt5Widgets.so.5(+0x2c13fc) [0x7f5379e9b3fc]
49 0x7f5379d323bc QAction::activate(QAction::ActionEvent) + 204
48 0x7f5379d2ffb2 QAction::triggered(bool) + 50
47 0x7f5377d861ea QMetaObject::activate(QObject*, int, int, void**) + 1850
46 0x7f537a5937f0 pqManagePluginsReaction::managePlugins() + 240
45 0x7f5379f14c57 QDialog::exec() + 471
44 0x7f5377d5662a QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 298
43 0x7f53394dfe13 /data2/nyue/systems/ParaView/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x5ee13) [0x7f53394dfe13]
42 0x7f53783e90db QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 187
41 0x7f537840db35 QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) + 261
40 0x7f537840c8ad QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 1837
39 0x7f5377d57dd8 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 280
38 0x7f5379d3d260 QApplication::notify(QObject*, QEvent*) + 704
37 0x7f5379d3618c QApplicationPrivate::notify_helper(QObject*, QEvent*) + 156
36 0x7f5379d908fb /data2/nyue/systems/ParaView/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libQt5Widgets.so.5(+0x1b68fb) [0x7f5379d908fb]
35 0x7f5379d8dd86 /data2/nyue/systems/ParaView/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libQt5Widgets.so.5(+0x1b3d86) [0x7f5379d8dd86]
34 0x7f5379d3c7cc QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) + 460
33 0x7f5377d57dd8 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 280
32 0x7f5379d3ddc8 QApplication::notify(QObject*, QEvent*) + 3624
31 0x7f5379d3618c QApplicationPrivate::notify_helper(QObject*, QEvent*) + 156
30 0x7f5379d73c28 QWidget::event(QEvent*) + 424
29 0x7f5379e19945 QAbstractButton::mouseReleaseEvent(QMouseEvent*) + 213
28 0x7f5379e1977a /data2/nyue/systems/ParaView/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libQt5Widgets.so.5(+0x23f77a) [0x7f5379e1977a]
27 0x7f5379e1845a /data2/nyue/systems/ParaView/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libQt5Widgets.so.5(+0x23e45a) [0x7f5379e1845a]
26 0x7f5379e18272 QAbstractButton::clicked(bool) + 50
25 0x7f5377d861ea QMetaObject::activate(QObject*, int, int, void**) + 1850
24 0x7f53795f95c7 pqPluginDialog::onLoadSelectedRemotePlugin() + 55
23 0x7f53795f94c1 pqPluginDialog::loadSelectedPlugins(QList<QTreeWidgetItem*>, pqServer*, bool) + 337
22 0x7f53795f6c84 pqPluginDialog::loadPlugin(pqServer*, QString const&, bool) + 68
21 0x7f5378f1a42b pqPluginManager::loadExtension(pqServer*, QString const&, QString*, bool) + 347
20 0x7f5376e8bd0f vtkSMPluginManager::LoadRemotePlugin(char const*, vtkSMSession*) + 479
19 0x7f53700448f9 /data2/nyue/systems/ParaView/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libvtkCommonCore-pv5.10.so.1(+0x5b68f9) [0x7f53700448f9]
18 0x7f5378f1befb vtkObject::vtkClassMemberCallback<pqPluginManager>::operator()(vtkObject*, unsigned long, void*) + 59
17 0x7f5377d861ea QMetaObject::activate(QObject*, int, int, void**) + 1850
16 0x7f537a5b0935 pqPluginSettingsBehavior::updateSettings() + 53
15 0x7f5376e83cf2 vtkSMParaViewPipelineController::UpdateSettingsProxies(vtkSMSession*) + 546
14 0x7f536bb65400 vtkSMParaViewPipelineControllerWithRendering::PostInitializeProxy(vtkSMProxy*) + 48
13 0x7f5376e88ac3 vtkSMParaViewPipelineController::PostInitializeProxy(vtkSMProxy*) + 163
12 0x7f5376eaa0ad vtkSMProxy::UpdateVTKObjects() + 29
11 0x7f5376efdaf2 vtkSMSettingsProxy::CreateVTKObjects() + 34
10 0x7f5376eaa843 vtkSMProxy::CreateVTKObjects() + 1091
9 0x7f5376ee03eb vtkSMSessionClient::PushState(paraview_protobuf::Message*) + 379
8 0x7f5376dc9b95 vtkPVSessionBase::PushState(paraview_protobuf::Message*) + 37
7 0x7f5376dce419 vtkPVSessionCore::PushState(paraview_protobuf::Message*) + 73
6 0x7f5376dcdc9c vtkPVSessionCore::PushStateInternal(paraview_protobuf::Message*) + 700
5 0x7f5376def754 vtkSIProxy::Push(paraview_protobuf::Message*) + 36
4 0x7f5376dee97c vtkSIProxy::InitializeAndCreateVTKObjects(paraview_protobuf::Message*) + 6604
3 0x7f5376defd0b vtkSIProxy::CreateVTKObjects() + 763
2 0x7f537a95b7f1 abort + 321
1 0x7f537a959e87 gsignal + 199
0 0x7f537a959f10 /lib/x86_64-linux-gnu/libc.so.6(+0x3ef10) [0x7f537a959f10]
( 654.610s) [paraview ] :0 FATL| Signal: SIGABRT
error: exception occurred: Subprocess aborted
