Remove additional edges to export correctly the mesh
Dear all,
I have this problem. The following mesh in cgns format, has the following structure and it is plotted with “Surface With Edges”
If I plot the mesh with “Feature Edges”, the mesh is different, triangular instead with hexaedron:
Unfortunately, when I export the mesh in other formats that I need (.vtm, .vtk, .stl) from the pyvista library in Python, the mesh is ever represented like in Feature Edges, but I want it like the first figure, with hexaedrons.
I generated, at the beginning, this mesh in ansys. Unfortunately, I didn’t find a way to export it without this problem. If I export the mesh directly in stl from ansys, paraview show me the mesh in “Surface with Edges” incorrectly:
Anyone that has some suggestions to fix this problem with Ansys, Paraview or Python?
Thanks in advance for your time.
Best regards,
Christian
The “Feature Edges” representation is equivalent to doing the Extract Surface filter, then doing the Feature Edges filter, and then displaying it. However, the Extract Surface filter will, as a default operation, subdivide the surface shape of the quadratic element. As a result, the “Feature Edges” representation of a quadratic hexahedral element will be split into triangles and displayed.
Therefore, a simple solution to correctly display quadratic element features is to first apply the Extract Surface filter to the loaded CGNS with the option Nonlinear Subdivision Level set to 0, and then use " Feature Edges" representation.
Thank you very much! It works. I could export the geometry with this discretization, thanks for your suggestion. I have only another problem: the geometry is visualized and exported only with the edges, without the possibility to visualize the surfaces. Here below the plot:
Is it possible to have this mesh, with the surfaces of the cell, like the previous plots?
Thanks again for your time.
Best regards,
Christian
I am sorry. I’m not really sure what you want to do.
If you want to output only the surface shape of quadratic hexahedral meshes in some format without subdividing them into triangles, you can output the result of the Extract Surface filter as *.obj or *.vtp from "File > Save Data".
Dear Kyoshimi,
I tried without success. I used your suggestion, but when I save the “Extract Surface” in vtp (or other formats), the mesh is not quadratic anymore.
Here below what I did, “Extract Surface wirh Nonlinear Subdivision Level to 0”
After, I exported the “ExtractSurface1” to .vtp format in the “prova.vtp” file:
Than, I loaded “prova.vtp” file, getting again the mesh with the subdivisions in triangles:
Do you have suggestions to export the “ExtractSurface1” correctly, please?
Thank you very much for your time.
Best regards,
Christian
Would it be possible to share your cgns file?
Yes, sure. Here attached the cgns file.
Regards,
Christian
single_sector_cgns.cgns (20 KB)
Thank you very much for the data.
I was not able to reproduce the issue when I tried ParaView 5.10.0 for Windows. Maybe the behavior is different depending on the version or OS.
Note: I had to add the MerbeBlocks filtering process as shown below.
Thank you very much, you’ve been very helpful!
I ever used Paraview 5.10.0 for Linux. I just did this procedure with MergeBlocks with Paraview for Linux and Windows. Once again, Paraview for Linux didn’t provide the expected result (at this point, it is a bug). Differently, Paraview for Windows worked correctly.
Christian
