Remove artificial default
Hi all,
When I am visualizing my results a red line appears in the center of my data. It seems to be created by very thin cell layer, see below. How can I remove it?
I already tried to slice at different locations and also to apply a threshold (which removes the red line but blank line appears).
Thanks a lot for any help!
Seems to me that is part of the results. Maybe is a really low value that you could try to remove adjusting the color scale. (I’m not sure though)
Thanks for your answer, I tried but i does not work since the red color is also observed in blue regions.
Can you share the dataset? If so, we can see what could be done to remove that “line”.
