Render of 3D surface in 2D Interaction Mode
I couldn’t find information about that so I take my chance here.
I am using pvpython 3.8 with on Paraview/5.9.1.
I attempt to generate a screenshot of a 3D surface in a 2D Interaction Mode.
The 3D surface is a cylinder made of triangles. The source is read from a .xmf file based of an HDF5 mesh file.
By setting the renderView.InteractionMode = '3D', the source is well represented.
cylinder_3d
However, I would rather use a 2D Interaction Mode for a question of perspective. But by setting renderView.InteractionMode = '2D', the PNG file obtained by SaveScreenshot() has a bad rendering:
cylinder_2d
Here is the triangle mesh of the source:
cylinder_2d_edges
Here is a simple example of my code :
renderView = GetActiveView()
renderView.InteractionMode = '2D'                # Or '3D'
xmf = XDMFReader(FileNames=['file.xmf'])
display = Show(xmf, renderView)
display.SetRepresentationType('Surface')
display.SetScalarColoring(None, 0)
SaveScreenshot('output.png', renderView, ImageResolution=(252, 256), TransparentBackgound=1)
Do you have an idea on how to have the same rendering in ‘2D’ perspective than in ‘3D’ ?
Have a nice day,
Thibault
Hi @thibaultDrt ,
Please share your data.
Best,
Hi @mwestphal ,
Thanks for your quick answer.
Trying to isolate my cylinder to share it here, I finally found the answer myself.
I was setting the renderView.CameraPosition to something far away from the renderView.CameraFocalPoint, thinking it didn’t really matter in 2D:
renderView.CameraPosition = [0.042, -0.006, 1000]
Apparently it mattered. Setting it to something closer (without being the real distance from the CameraFocalPoint) fix the problem. And if I get further ([0.042, -0.006, 2000]), the quality of the rendering goes even lower.
Sorry for bothering, and hoping it could help someone else,
Best,
