but i want to see these two materials in one renderview simultaneously! because i want to see the flow of two materials… the below picture is what i want
this is result of OpenFOAM, that is one of CFD code. the reason why i should combine them together is that i want to see the whole flow motion of two materials (oil and water) conveniently … the separate motion with two render view is inconvenient to see them…
umm, if you don’t mind, could you tell me more detail…? sorry…
i searched the information of calculator filter you mentioned, however, to achieve purpose to combine two render views, i may think that this filter does not look like proper
oh!! i found it, just “+” button! oh thank you very much!
if you don’t mind, can i ask you one question?
i want to fill the different color to different material, but when i do the “+” calculator filter, the whole material are combined at same color, so i have difficulty about distinguishing materials
Besides the way Mathieu described you could use the clip filter by scalar type…just use it twice with certain scalar (above value, and so on…). Make sure that both clips are activated in view…
Best
