Rendering the frames of an animation on several machines: a plugin, and a question about real sessions
A note first: I am the developer of the plugin this post describes.
An animation through the time steps of a transient result is a long job on one workstation: for every frame ParaView loads a step and runs the whole pipeline. The frames do not depend on each other, so I wrote a plugin that sends them to several machines.
It adds a panel to ParaView 6.2 on Windows, Linux and macOS. The plugin captures the session as it stands, pipeline and camera included, and the frames are rendered on the computers of a group you put together, each frame whole on one machine. The images or the finished video come back to your disk.
The machines run OmnibusCloud. If the name is new to you: the idea is close to BOINC or Folding@home, where work goes to ordinary computers in the hours they would otherwise sit idle. Here the work is your own, and you decide whose computers take it. They need no ParaView installed, because the rendering side brings its own. That side is open source, in the OmnibusCloud/Controllers repository on GitHub.
What works: stills and animations through the time steps, with a moving camera if the session has one. The machines read .vti, .vtr, .vts, .vtu, .pvd, .pvtu and OpenFOAM cases, and the plugin adds a reader for CalculiX .frd results that needs no account. The filters a session may contain are a fixed list, given in the guide. Ray tracing with OSPRay runs on the machines, on the CPU.
What does not: .pvti, OpenVDB and the HDF5 family are not read yet. A session that uses the OSPRay materials library, extra lights or an HDRI skybox is refused before anything is sent. One frame is never split between machines, so a single heavy still gains nothing, and every machine needs the memory for a whole frame.
I am not a ParaView specialist, and the cases I tested are the ones that looked representative to me. That is the reason for this post. Which parts of your real sessions would such a tool have to handle before it is useful to you: ray tracing settings, particular filters, formats? If you have a session you can share, I will run it and report here what happened.
The guide: https://omnibuscloud.io/getting-started/paraview?src=forum-paraview
Two minutes of video: https://youtu.be/c7qoe5lp210
ParaView is developed by Kitware and the ParaView community. OmnibusCloud is not affiliated with or endorsed by Kitware.
