"Requires an input" error on all filter options with vtk data file (that has data)
Hi all,
I have a VTK dataset contaning 3D velocity from a simulation and I have just used the GUI “open” file button to load the data. I am able to represent the data using all the “surface”, “Points”, “Points Gaussian” options, however I can’t do any computations with the data.
Every filter is greyed out and if I hover over the calculator or ‘contour’ or other computed representations I get the error “Requires an input”. However there is data in the vtk, as I can see it colored in points mode.
Is there some step I’m missing or some way to force paraveiw to use the velocity data?
Best regards,
Robert H.
Press Apply
Wow that worked… Thank you! :sweat_smile: !
