Hey there, I am running into issues getting a segmentation fault when I am using the ‘Resample to Image Filter’ and setting my sampling dimensions too high.
For example, using the dimensions [2000, 650, 800] on my large AMR dataset works fine, but when bumped up by 1.5 or 2 times from there I get the crash.
I would expect this to be memory or CPU limited, but this doesn’t seem to be the case here as I still have memory and CPU to spare.
Is there an upper bound built into the filter or some sort of multiplication guidelines I need to follow here?
Thanks,
