reset Paraview using a command line
Dear,
I am using Paraview 5.9.0 on Ubuntu, I have made a change in the settings where I activated the parallel processing with min of 32 processors and now I can’t open paraview.
Is there a way to reset the setting using a command line so that it can go back to the original settings?
Thanks
These are usually stored in $HOME/.config/ParaView*. You can move these directories out of the way to get a clean configuration.
Thanks for the answer Ben, these are in the .config/Paraview file: ParaView5.9.1.ini ParaView-UserSettings.json servers.pvsc
So I can empty the .config/Paraview and start Paraview again?
I’d save it off in case there’s something you still want there, but yes, making ParaView not find them anymore should get you a pristine configuration.
Perfect, thanks!
