Reset Session programatically in python macro
I’m running a macro with loops that use a lot of memory. What I’d like to do is to clean the memory between loops. However if I add a
ResetSession()
in the macro, Paraview crashes.
I tried something like
for x in GetSources().values():
Delete(x[0])
but it doesn’t seem to clean the memory.
Is there a solution to this problem?
Thanks,
Gianmarco
This is a known issue, unfortunately.
https://gitlab.kitware.com/paraview/paraview/-/issues/18261
A work around is to use
Disconnect()
Connect()
Thank you for your reply Cory.
It seems, however, that also the Disconnect() / Connect() method crashes if used in a macro.
Isn’t there any other way to free memory while in use? I could also accept to close and reopen Paraview, as long as it is automated.
Thanks
I just marked this as a showstopper for the 5.11 release. (Reference the bug Cory pointed at.) I hate crashes, and it looks like there isn’t a workaround. Thanks Gianmarco for reporting.
