I use a custom Lidar system (non-rotating, high speed), and I wanted to explore the possibility of using LidarView with it.
I’m interested in having ROS 2 data directly into LidarView, in real-time. So not only reading ROS2 bags but, for instance, LidarView subscribing to PC2/IMU topics.
Additionally, real-time odometry would be a nice addition.
I’m aware from this link that these are planned features. I was just wondering if this will likely be implemented in the near future, or if it is more likely a low-priority project?
This feature is already implemented in LidarView (but is not yet part of a release). You can download the nightly version of LidarView following this link (click on download artifacts under Actions).
The topics currently supported are:
sensor_msgs/msg/PointCloud2
sensor_msgs/msg/Imu
sensor_msgs/msg/NavSatFix
nav_msgs/msg/Odometry
oxts_msgs/msg/NavSatRef
To create a subscriber you have to create a ROS 2 PointCloud DDS Subscriber or ROS 2 Table DDS Subscriber source.
Let me know if you encounter any issue or if you have any feedback / feature ideas.
I tried the LidarView Nightly build, and was able to subscribe to both PC2/IMU ROS2 topics:
Data were displayed correctly on the 3D view panel.
PC2 data were reported in ROS2PointCloudDDSSubscriber1–>Point Data, and IMU data were reported in ROS2TableDDSSubscriber1–> Row Data.
Regarding IMU data, I tried both raw IMU data, and also IMU data coming from Madgwick filter (ROS package).
–> I am wondering if there is a way to enable Odometry in real time already, in the Nightly build? (with data from PC2 + Madgwick filter for instance, via ROS 2 topics)
