Hi all,
I wonder if someone would be able to come up with a good solution regarding my issue.
My python script is designed to extract nodal temperature (NT11) variable from abaqus and eventually the script writes .vtu file using ParaView XML format.
I haven’t had any issue with my script for a couple of years, but recently ran across new issue.
With this FE model,
the script does make .vtu without any error in abaqus, but Paraview shows nothing when import the .vtu file. But I am noticed something is wrong because the .vtu file size is less than 1KB.
Since I haven’t gotten any errors either from abaqus or Paraview, I have no idea what causes this issue.
So could someone please take a look at it?
abaqus input, python script, .vtu files are attached.
meltingpool.py (4.5 KB)
paratest.vtu (648 Bytes)
paratest.inp (372.1 KB)
*ps1) if you would like to use my script for any reasons, you would be welcome to use.
*ps2) when tested with different model, the script works perfect as shown below:
