I do all steps from here
when I browsing at http://localhost:9000/ its blank and I get some errors in the log file logs 63d41a80-2adb-11e9-80cd-901b0edada47.txt (2.0 KB)
Can you help me?
Thanks,
O Barak
You should use ParaView 5.6 but otherwise it seems that the file you tried to load at startup is not valid or does not exist.
That guide was contributed by the community to show how to edit the Visualizer application to automate the loading of files at startup by providing some url arguments.
Is your machine named paraview? and did you properly setup an apache server?
BTW, do you know that you have two thread on the same topic?
