I downloaded ParaView 5.9.0 and Visualizer localhost8080 works!
I want to connect ParaView and Visualizer, what should I write in “Choose Server Configuration”? As you can see there is also a problem with Python library, see attached image.
Thanks. I tried with pvserver --multi-clients and wrote the server configuration in Paraview (first image). As soon as I run http://localhost:11111/ i get these errors.
Yes that is expected. The pvserver protocol has nothing to do with http. You can only connect your browser to a pvpython pvw-visualizer.py ... process. But that process can connect to a pvserver by using those arguments. In the same way, the ParaView Qt client can not connect to a pvpython pvw-visualizer.py ... process. I hope that clarify some of the confusions.
