How does one show the Catalyst example (specifically, CFullExample) in ParaView through the UI? CTest works:
Start   5: CFullExampleTest
5/2787 Test   #5: CFullExampleTest …   Passed    1.04 sec
I’d assume you just do Catalyst–>Connect, hit ok, then launch the CFullExample like this:
./bin/CFullExample …/Examples/Catalyst/CFullExample/SampleScripts/feslicescript.py
Then the ParaView client clearly connects to the Catalyst server and loads the pipeline, but then I get this error before anything is applied:
ERROR: In /home/knolla/work/ParaView-weatherinabox/VTK/Parallel/Core/vtkSocketCommunicator.cxx, line 808
vtkSocketCommunicator (0x555558a03920): Could not receive tag. 1
ERROR: In /home/knolla/work/ParaView-weatherinabox/ParaViewCore/ClientServerCore/Core/vtkTCPNetworkAccessManager.cxx, line 297
vtkTCPNetworkAccessManager (0x555555c2dcd0): Some error in socket processing.
I wonder if the issue I’m seeing is not with CFullExample itself, but rather with how I’m loading it in the ParaView UI.
Note: any Catalyst example that runs through the ParaView UI will be fine for my purposes; it doesn’t have to be CFullExample.
Thanks for any help,
Aaron Knoll
NVIDIA
