Hello
I want to run a bash file in which I open up Paraview and run a series of filters from the script. How do I do that?
Thanks
Tejas
Hello
Thanks
Tejas
This is a standard usage for pvpython.
https://www.paraview.org/Wiki/ParaView/Python_Scripting
https://www.paraview.org/python/
https://kitware.github.io/paraview-docs/latest/python/
Thanks. I was able to run pvpython on my local machine. I want to be able to run paraview on another machine through ssh. I used ssh -X computer@ssss.com.ss but it is failing. Could you please give me any input on this problem? Also, I am using a trace to setup automated processing. I want to save a state of the stuff I am doing. But it does not record on the trace. Is there another function in order to record the save state function?
Thanks
Do not use -X or -Y with ParaView
Do not use -X or -Y with pvpython
Do not use -X or -Y with pvbatch
It is not supported and never will be.
You have to use the client/server mode of ParaView, take a look here :
https://www.paraview.org/Wiki/Setting_up_a_ParaView_Server
