Saving high quality image
Hi
How can I save high quality (>300dpi) image in paraview?
Hi @kokebdese
Just increase the resolution in the screenshot window.
Best,
In File > Save Screenshot, after you choose the file name, you can use the Screenshot Options dialog to increase the image resolution, even beyond the screen resolution.
@mwestphal @danlipsa
I appreciate your answers, nevertheless, how can I save a section of screen which contain the object (item) without including all screen. Eg. Here I only wanted to save the PD, but all screen is included. Thanks
kk
Just zoom on it ? You can use zoom to data.
You can also turn off the colored scale and the axis reference from the screen (if you want to).
@SebastianSalazar42
Nice, how? :pray:
turn off colored scale: In “Active Variable Controls” Toolbar, clic on “Toggle Color Legend Visibility” to turn on/off the colored scale. To activate “Active Variable Controls” Toolbar, go to View > Toolbars > The first one should be active.
turn off axes reference: In properties window, go down and find “Orientation Axis”. Uncheck “Orientation Axes Visibility” to disable it.
@SebastianSalazar42 : Thank you so much!
@SebastianSalazar42
May I save the file by making the background as none? I don’t want a white or any other colour in the background. Thanks
-To remove the background from the image, you need to enable the “Transparent Background” option. The option’s location may vary depending on the version of ParaView you are using, but it’s typically found in the “Advanced Properties” section or in a separate tab called “Advanced.” Check the “Transparent Background” option. This will make the background of the image transparent. Adjust any other desired settings, such as the image size or quality. Once you have configured the settings, click the “Save” button to save the image with the specified filename and format.
(The option to save an image with a transparent background is not available in ParaView 4.4.0. This feature was introduced in a later version of ParaView.)
Another option is that u simply save the screenshot with white background (or green) and then you remove it with Photoshop (usually will take you like 5 minutes or less). Finally save it as png.
@SebastianSalazar42
Nice! I got it! Thank you!
