Scale bar for small numbers
scale_bar
Numbers from my data are small.
I applied “Rescale to Data Range” and it showed as attached.
What I want is "I do not want the rounded numbers for top and bottom values."
I also applied “Rescale to Custom Data Range”, but it didn’t work.
Is there any tip for this?
Thanks!
Welcome ParaView, @Hokon_Kim
You can change the formatting of the minimum and maximum numbers using the color legend properties. In the Color Map Editor, click the button in the upper right corner to open the Edit Color Legend Properties dialog. Change the Range Label Format to your desired C-style format string.
