I am using the Find Data Matching to find the maximum and minimum values as well as location. From the attached Figure the mark point clearly shows on (0.65, 0.85,0) but in the data column it is (0.065,0.085,0). How do I change the scale to correctly determine the max, min and location?
Hi @uog !
I don’t see on the figure where you can see that the point coordinates are (0.65, 0.85, 0). Could you please show where does this information comes from?
Hi Kitware,
Thank you so much for your reply. I imported here the data from OpenFoam. My domain is a unit square such that [0 1]^2. So from the Fig. we can say that the min point is located (0.65, 0.85, 0). Actually, data from [0 1]^2 scale here to [0 0.1]^2. But I do not understand how to display it on the original scale.
