script generated with trace doesn't work with pvbatch
xz_animation_vortmag_vtk_series_batch.py (6.7 KB)
Attached is a file generated using paraview trace utility. The scripts runs without any error when runscript is used in gui. However, the script fails when pvbatch command is used. It give the following error.
File “/mnt/sdb/Research/GATS/MURI/cases/GW20/paraview_macros/xz_animation_vortmag_vtk_series_batch.py”, line 139, in
layout1.SetSize(914, 695)
AttributeError: ‘NoneType’ object has no attribute ‘SetSize’
Can anyone help me with this?
Hello, I have the same problem, were you able to solve it? Thanks
Without really digging into it, my guess is that you need to recreate your script. In theory older scripts run with newer versions of ParaView, but in practice I have seen it be problematic. I believe this was true after 5.9.1. You can read which version of ParaView created the script at the top.
