Paraview first-timer here. Our app creates HDF5 files with a very simple structure:
h5dump -A cart_cr2130.h5
HDF5 "cart_cr2130.h5" {
GROUP "/" {
   DATASET "Bp" {
      DATATYPE  H5T_IEEE_F64LE
      DATASPACE  SIMPLE { ( 151, 151, 151 ) / ( 151, 151, 151 ) }
   DATASET "Br" {
I just installed ParaView 5.6.0 in my workstation (ArchLinux), and I tried to open that file, but I get a Segmentation Fault as can be seen below:
[angelv@comer ~]$ paraview
ERROR: In /home/angelv/spack/var/spack/stage/paraview-5.6.0-rj74wdfmntjmqhcxelyksaagllsxrw2z/spack-src/VTK/IO/VeraOut/vtkVeraOutReader.cxx, line 253
vtkVeraOutReader (0x55eeaed90200): Can't open group /CORE
[comer:22212] *** Process received signal ***
[comer:22212] Signal: Segmentation fault (11)
[comer:22212] Signal code: Address not mapped (1)
[comer:22212] Failing at address: (nil)
[comer:22212] [ 0] /usr/lib/libpthread.so.0(+0x13d00)[0x7fe96bd62d00]
In VisIt I use the Pixie reader for this type of files. Is this (or equivalent) available in ParaView to read basic HDF5 files like this one?
I also tried with a .xmf file which provides a better description of the data in the .h5 file (dimension coordinates). This one doesn’t crash anymore, but I don’t seem to be able to get any meaningful plot out of it either. I don’t know if I’m doing something wrong or there is something wrong with the files (as a reference, with VisIt, which I’ve been using lately, I can read without problems the .h5 directly, or the .xmf file).
Just trying to see if ParaView will fit our needs. Any help appreciated. Many thanks,
AdV
