Segmentation fault with OSMesa binary on Ubuntu 24.04
I am trying to run pvbatch from the OSMesa ParaView build on Ubuntu 24.04 with a simple example script, and I get a segmentation fault.
There is a minimal example at GitHub - cfdemons/pvbatch-test with instructions for testing it with Docker.
I installed the Ubuntu packages
libglapi-mesa libgomp1 libgl1
to resolve missing symbol errors with pvbatch. I’m not sure if these are the right packages to install.
When I run it, I get
$ docker run paraview:test /opt/ParaView-5.13.1-osmesa-MPI-Linux-Python3.10-x86_64/bin/pvbatch /scripts/test.py
error: exception occurred: Segmentation fault
Thanks. Not sure why I didn’t come across that FAQ! I assume I can’t use the EGL version if I am on a headless machine with no GPU? So I will have to compile it myself.
Actually, with modern version of the libegl, you can use it with the CPU only!
