Hi all! I load 2 similar .stl models on 2 distinct RenderView and I link the cameras. So when I move one model in the first RenderView, the other in the second RenderView moves too. At this point I want to select a set of points points contemporary on the 2 models using ‘Iteractive Select Points on’. How can I link also the selection of the points between the 2 views?
Thank you!
Use SelectionLink by right clicking on the pipeline browser item
I already did it, but I can only move the 2 models. I want to select points (coordinates) on one model (RenderView1) and see the correspondent ones on the second model (RenderView2).
This is exactly what SelectionLink is for. If this does not work, please share your data.
