Hej,
when using texture images in a session which will later be copied to another drive/directory I frequently used the code below to be able to keep the image (using the “Search files uder specified directory” on loading the state):
rv1=GetActiveViewOrCreate('RenderView')
profile=XMLPolyDataReader(FileName=['D:\\projects\\load_image.vtp'])
pathToTextureImage='D:\\projects\\image.png'
Display=Show(profile, view=rv1)
Display.SetRepresentationType('Surface')
texProxy = servermanager.CreateProxy('textures','ImageTexture')
texProxy.GetProperty('FileName').SetElement(0, pathToTextureImage)
texProxy.UpdateVTKObjects()
servermanager.Register(texProxy, registrationName='prof_IL1800_image')
With PV 5.10.0 servermanager.Register is not valid any more. What is the correct way to register the image in the newest ParaView release?
Thanks in advance and cheers,
Venke
